Parking lights come on when door opens - how to turn off
I'm not sure if there is an OEM way of doing this on the newer trucks, but I used to have a 99 250 that I modified to do exactly what you are talking about. Obviously features and wire codes have changed over the years, but it was pretty simple, all I used was a test light probe, some strippers, solder gun, and the OEM dimmer switch. I cut a hole next to the existing dimmer, and after probing around the wires to the original switch I made some cuts to transfer everything that got power from opening the doors through the second dimmer switch first. So the second "dimmer" switch, was actually just an on/off controlling weather the dome lights and door lights would get power from opening the door or taking the key out. I only used the dimmer so it would look like original parts.
hmm never thought of doing it that way.
I was thinking of putting a switch in the wire that is on the door latch. the only downside to this would be that the vehicle would always think the door was closed, and would thus leave interior items such as radio on untill it times out.
It is a government Law enforcement vehicle. it is used for surveillance.
someone told me that Texas game and fish just bought a bunch of new ford P/U trucks and obviously that feature doesn't work for them. They supposedly were able to take them back to the dealer and have a "police blackout" programed into it.
I asked my little podunk dealer here but they wanted me to bring it in so they can "look at it: without even knowing if they could change it. I think I will check with a larger dealer about this.
It just seems so wrong to go cutting wires on a brand new truck with only 2,000 miles. although worse has already happened. I got hit on the interstate with only 1.100 miles on it.....
I checked the service manual and the wiring diagram manual, the functionality for the lights and the key is controlled within the Body Control Module. It shows the control relays for these features as non-serviceable items. My guess it's probably located on a printed circuit board. The BCM receives data from the HS-CAN bus to determine the state of these features. As was pointed out earlier there must be a police option available from Ford, only a guess but perhaps a replacement BCM.
John
John
John
John
Go to your favorite dealer and ask them to hook your vehicle up to the IDS. Under module programming, programmable parameters, go to Personality, (or exterior lighting depending on the model) then police programming and then select welcome illumination. Disable it. Some models may even disable the dome light though. E350 I did disabled the dome but an Escape did not.
Have a good day.
Have a good day.
kwozz48
1999 to 2016 Super Duty
01-04-2024 04:49 AM
