Parking lights come on when door opens - how to turn off
2012 F-250.
as said, when I open the doors the parking lights come on. how can I disable this? likewise can I disable the interior lights coming on when I remove the key but do not open door? |
I'm not sure if there is an OEM way of doing this on the newer trucks, but I used to have a 99 250 that I modified to do exactly what you are talking about. Obviously features and wire codes have changed over the years, but it was pretty simple, all I used was a test light probe, some strippers, solder gun, and the OEM dimmer switch. I cut a hole next to the existing dimmer, and after probing around the wires to the original switch I made some cuts to transfer everything that got power from opening the doors through the second dimmer switch first. So the second "dimmer" switch, was actually just an on/off controlling weather the dome lights and door lights would get power from opening the door or taking the key out. I only used the dimmer so it would look like original parts.
unless someone has a wiring diagram or detailed instructions you might just have to take some time with a test lamp and it is fairly easy to rig up
hmm never thought of doing it that way.
I was thinking of putting a switch in the wire that is on the door latch. the only downside to this would be that the vehicle would always think the door was closed, and would thus leave interior items such as radio on untill it times out. |
Have you checked in your owners manual?
I wonder if this feature can be turned off through IDS? |
Originally Posted by DrFord
(Post 13064314)
by the way, who is it you are stalking?lol. I don't want to be an accomplice haha. But honestly, just curious, why don't you like your lights coming on?
Originally Posted by jroberts257
(Post 13064888)
It is a government Law enforcement vehicle. it is used for surveillance. someone told me that Texas game and fish just bought a bunch of new ford P/U trucks and obviously that feature doesn't work for them. They supposedly were able to take them back to the dealer and have a "police blackout" programed into it. I asked my little podunk dealer here but they wanted me to bring it in so they can "look at it: without even knowing if they could change it. I think I will check with a larger dealer about this. It just seems so wrong to go cutting wires on a brand new truck with only 2,000 miles. although worse has already happened. I got hit on the interstate with only 1.100 miles on it..... |
Well if you don't mind paying someone to do it you might try a local audio installer or shop that does any kind of electrical or custom installation. Any place like that would have the intelligence and experience to figure out a good clean bypass to get your results your looking for
they would more than likely be much cheaper than the dealer. And might have more creative ideas on how to get it done. Most of those dealer mechanics are like robots and do everything by the book, which doesn't normally work well for aftermarket installs
I checked the service manual and the wiring diagram manual, the functionality for the lights and the key is controlled within the Body Control Module. It shows the control relays for these features as non-serviceable items. My guess it's probably located on a printed circuit board. The BCM receives data from the HS-CAN bus to determine the state of these features. As was pointed out earlier there must be a police option available from Ford, only a guess but perhaps a replacement BCM.
John |
Originally Posted by m50steel
(Post 13069014)
John |
(Post 13070615)
HMM thanks for the info. Guess I will have a look at it
Have a good day. |
