Help with rivets - radius arm bracket!
OK, this shouldn't be that hard, but on my 77 F-150, I drilled out two rivets on the radius arm bracket, last summer. Believe I used either a 5/16 or 3/8 bit. Had to notch the front of the rivet with a dremel cut off tool and the head of the rivet came right off and I was able to push through the rest.
But on my 74, it's almost as if the rivets have bonded to the frame and bracket! I've tried two bits, and have broken both - Dewalt Titanium bits. The bits cut very well, but thinking maybe I need to go back to Cobalt or Black oxide bits. The titanium bits are light, not very dense. Any hints with this? Are the rivets from 74 made with higher carbon steel than the 77's?
OK, thanks HIO Silver. that's a good approach. I managed to get the first one. Key is to use the Cobalt bits - much stronger and cut the rivets like butter. I like the idea of the X on the head - I did that with my Dremel that way - cut the X in the head. Damn rivets. **** on the rivets. Rivets on the ****... Sounds like Jed Clampett.
Correct bolt is a 7/16 - 18, I believe.
Seriously, all these guys drilling or punching by hand?! I did a couple with a torch and a punch a few years ago, never again. took me less than an hour with the air hammer to remove every rivet and punch them out on the front suspension the other day. Cut an X in the head, use the chisel to punch the head off, and then the punch bit to push it through. I had to cut the head off both sides on a couple, but so much easier than doing it by hand.
