g/p relay
g/p relay
i got some info here the other day, wanted to put some #s out there, both batteries 12.57 and clean. relay big term. is same with key off 12.57,always hot. turn key on wts for g/p,s -the always hot one is 11.50 and other big one is 11.24 -both little ones have .02 with key off. checked all connections i could get to. unplugged wire going into v/c just checked 1 had 11.24[1 going to g/p] any sug. preciated
g/p relay
my 96pws used to not start under 50 deg. [had to plug itin] found some battery issues now it starts at 30 or so but i have to cycle threw g/p system 3-4 times then crank it.--new g/p relay ,g/p`s,fuelheater-getting juice to g/ps,11.24v.-relay clicks and seems to funtion properly-all fuses good.harness maybe 2yrs ole[$1,000]
The 11.50 -> 11.24 drop is 0.26V, which is within the limit (0.3V) of what's considered a "good" relay. Next thing to measure is the glow plugs themselves. Check resistance at the valve cover connectors. I've heard lots of ranges, but between 0.5 and 2.0 ohms should mean that the plugs are good.
Once it starts, are you getting any/much white smoke?
on
1 Post
Like madpogue said, the glow plugs stay on a lot longer than the WTS light. I turn the key on and wait up to a minute sometimes. If you want to see how long they actually stay on, watch your voltage gauge in the dash. When you turn the key on, the needle will be down around the "N" in NORMAL. Don't try to start the truck, just watch the gauge. When you see it jump up to about the "R", the glow plugs just went off. Time it and see how long they stay on, and you can base your wait to start time on that.
Perfectly normal on a cold truck; that's the glow plugs timing out (see owner's manual). That period should be shorter, 30 seconds or so, on a warmed-up truck. It's based on EOT - engine oil temp - reported to the PCM. If you can get access to a scanner / gauge that reads live data, check the EOT value when the truck is warmed up; that sensor may not be accurately reading the oil temp.
