Ford 4.2L Electrical problem need ideas PLEASE!
Old 04-07-2013, 12:37 AM
nat1811's Avatar
nat1811
nat1811 is offline
I have a 2002 ford f-150 4.2 liter v6. When i press on the gas the car shudders and struggles and you can here a popping sound it does it worse in higher gears when i shift early I've replaced air filter fuel filter spark plug wires and plugs were replaced within 10,000 miles even one of the plug wires was broken and even having replaced them still the problem occurs please help!!
Old 04-07-2013, 12:38 AM
nat1811's Avatar
nat1811
nat1811 is offline
Any help would be so appreciated i don't have a ton of money to put into this right now and i really would love to get it running right
Old 04-07-2013, 07:46 AM
JWC 3's Avatar
JWC 3
JWC 3 is online now
If the popping sound is coming from the intake / air filter area , it may be a lean pop . Ck fuel pressure .
Old 04-07-2013, 03:48 PM
nat1811's Avatar
nat1811
nat1811 is offline
Thank's i will check right now thanks for the reply
Old 06-14-2013, 12:05 PM
brvanbibber's Avatar
brvanbibber
brvanbibber is offline
Timing
Stop where you are. The 1st thing you should do is confirm engine timing all aspects that include plug wires! If you continue with the steps you are attempting you could spend a lot of unnecessary money not to mention damage to engine!
motoservdog
3.8 & 4.2L V6
10-25-2007 01:01 AM
levcar
1997 - 2003 F150
08-09-2004 07:52 PM
2FordTrucks
1997 - 2003 F150
06-08-2003 07:05 PM
ericatUNC
1997 - 2003 F150
11-26-2002 07:20 PM
swampfox35173
1997 - 2003 F150
05-22-2002 03:01 PM
Quick Reply: Ford 4.2L Electrical problem need ideas PLEASE!
