oil
oil
my last two oil changes i have noticed my oil gauge has droped from the m in normal to the the o. i would like to check my pressure with a manual gauge at the hpop. warm engine temp what psi ? secound do these rotory oil pumps get weak or just quit when its time. 95 7.3 245000miles. thanks for any input.
That is where the LPOP Pressure is measured.
And yes, the pumps can get a bit weak, but using one of the idiot gauges to judge if its bad isn't really accurate. So, a check like you're saying isn't a bad idea.
Did you change oil types?
First of all the Dash guage is a glorified Idiot light....If you want to test LP oil you need to plumb a line to a place like the port beside the oil filter or the Turbo Pedestal...If you want HP oil you need to use a 0-3000 psi guage and plumb into one of the oil rail pugs on one of the heads.....
I would say if your positive that you have the gauge connected good and are getting a good reading, then maybe you do have a problem. Both my PSD's are 20lb at idle with the oil hot and 50lb running down the road. Cold I get 55lb at idle.
I should know that seeing the troubles I had with mine.
I don't know what would cause it to read a low number like that, even voltage wise.
When I had trouble with mine, it just flicked back and forth the whole trip. The connection on it was bad and the vibration of the motor was putting it on and off.
Jolly Roger Joe
06-12-2018 07:58 AM
Sooper Camper
05-24-2013 12:31 PM
armstpe
26
04-29-2005 12:58 PM
