Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
E450 Loosing power
Old 04-03-2013, 06:37 PM
Crackers 27's Avatar
Crackers 27
Crackers 27 is offline
Cool E450 Loosing power
2008 E450 RV with 11,000 miles with power lose on acceleration. Being told after replacing fuel filter and fuel pump that now cause is rust in fuel tank.
Old 04-18-2013, 09:01 AM
gregfloren's Avatar
gregfloren
gregfloren is offline
e450 loosing power
I have a e450 2005, 31ft class c rv with 6,000 miles, had to have the throttle block replaced, I didn't know it was a v10, I've been using regular gas with no problem except for power. After replacing the throttle block it pings real bad even with premium gas, not sure what's up with that, I will add an octane additive to see if that helps
Old 04-18-2013, 01:52 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Pull the codes from the OBDII system.
Old 05-05-2013, 08:27 AM
Crackers 27
Fuel tank was replaced and problems solved after spending $3,200. and 5 nights stay in hotel/meals. How can a 2008 RV that was finished in 2009 have rust in the tank? Is FORDS quality that bad? I was told it was because I didn't keep the tank full while in storage for 4 months. I guess we have the very first RV ever that sat for four months and FORD didn't take that into consideration when they marketed this vehicle. (NOT) FORD has stated they will not help us. That's unfortunate as we are members of a group with membership of 1.3 million and a quarterly magazine that welcomes stories.
Old 05-05-2013, 08:29 PM
gandrimp's Avatar
gandrimp
gandrimp is offline
I think you can put some of the blame on our fuel. The ethanol makes the fuel go bad very quickly. It seperates from the gas, it also draws water.
5 years does seem like a short time to have rust that severe.
Old 05-06-2013, 05:06 PM
merlynr's Avatar
merlynr
merlynr is offline
kinda strange huh? My 1952 IH "H" sat all winter with a couple of gallons in it and started up like it was run the day before. The gas tank hasn't been touched since 73 and probably not before then either.
Old 05-07-2013, 09:00 AM
gregfloren's Avatar
gregfloren
Thanks for all the info, I did add a gas additive when I stored it. I will add an octane additive and premium gas to see if that works.
lilsmokey
13
11-04-2012 10:15 AM
ranbro
12-30-2011 08:01 PM
rednekrebel28
05-11-2010 09:27 PM
tazo
05-02-2008 05:19 PM
ecsmith0624
1978 - 1996 Big Bronco
11-24-2003 02:17 PM
Quick Reply: E450 Loosing power
