Having trouble removing the transmission crossmember
I am trying to drop my transmission and I need to remove the crossmember. I have all the bolts loose except for the four that are in the supporting brace that bolt to the top of the frame. My problem is I cannot remove those four bolts because the cab is a about an inch above them. How am I suppose to remove the crossmember?? What else do I need to do?
Thanks,
Airsoft1779. 1984 F150, 302, 3 speed transmision, 4x4
Thanks,
In my experience, you can leave those 4 top bolts in place, just loosen them off so the braces can tilt upwards.
They didn't completely clear the cross member, but lifted enough that I could knock it out from under them with a heavy soft-face hammer, without much effort; same going back in.
The true duals I had on the 82 I sold went either side of the passenger-side brace and the pipes were tack welded together fore and aft of the brace. No way to tilt it up, had to take it off. Part of the reason I wasn't too interested in duals. And don't get me started on headers - oh, that's another thread.
bullnose1985
15
08-04-2019 08:07 PM
roshan
09-03-2013 08:46 AM
4x4countryboy
05-11-2012 12:03 AM
