97 7.3 front engine bracket problem
Old 03-29-2013, 09:32 PM
zthayer's Avatar
zthayer
zthayer is offline
Hello, I wanted to run this by everybody and see if anybody has ran into this issue. My Ford F-350 7.3's bracket that is right behind the belt pulleys where it looks like the power steering pump comes through and bolts to the bracket. one of the bolts has snapped in two and the bracket cracked around the other bolt causeing the power steering pump pulley to turn while the belt is trying to run straight. I got the truck home but now I will have to deal with that. My question is has anybody else had this happen just out of the blue? or has it happened becuase bolts were over torqued from previous work? I also wanted to know if someone would know where I could get one of those brackets and what a fair cost would be.
Thanks
Old 03-29-2013, 09:38 PM
95_Dually's Avatar
95_Dually
95_Dually is offline
I have not had that happen. Not sure what may have caused it unless something is out of balance causing the belt to bounce around. A wrecking yard would be your best bet unless someone here has one laying around from another project.
Old 03-29-2013, 10:13 PM
Mdt1992's Avatar
Mdt1992
Mdt1992 is offline
i had that same bracket brake on my old truck about 3 or 4 years ago, started the truck up one morning, backed down the drive and pop all i heard was clanking metal and belt squeal, dont know what actually caused it but ended up getting that bracket off ebay dont recall the price, didnt really come up with anything but high prices at only a few places. this should be the part number F6TZ 19E708 AA.
Old 03-30-2013, 09:32 AM
zthayer's Avatar
zthayer
zthayer is offline
Ok I was curious if anybody ran into this problem before. I had a oil plug replaced which required the bracket to be removed and other items. I was thinking that maybe the bolts were torqued to tight or something. How would you check for balance? This is my first Diesel Truck so I'm not up on the balance info.
Old 03-30-2013, 09:38 AM
zthayer's Avatar
zthayer
zthayer is offline
Whats the actual technical term for that bracket?
Old 03-30-2013, 11:22 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is online now
reps sent Mdt.
Old 03-30-2013, 07:32 PM
zthayer's Avatar
zthayer
zthayer is offline
I don't understand old bird is that code?
Old 03-30-2013, 07:46 PM
zthayer's Avatar
zthayer
zthayer is offline
Does anybody have advice on where to go and get parts? There is a guy that works on my truck but he uses the dealer for parts. for a compressor bracket I found one for $159.00. I'm in Kentucky so if someone knows a local place I would appreciate knowing about it. Thanks!!
Old 03-30-2013, 07:47 PM
oldbird1965
No, its not code, sorry for the confusion. In post three #3 he helped you with info and a part number so I gave him a reputation point. To the right of the post number and the word permalink is a red button. If you click on it, it gives you the opportunity to tell the person that you were helpful. The more reps a person gets, the more green dots you get. After all this explaining, are you going to give me a reputation point, LOL Just kidding!
Old 03-30-2013, 07:48 PM
oldbird1965
For parts out of a junk yard car-part.com is a good place.
Old 03-30-2013, 07:50 PM
fordpride's Avatar
fordpride
fordpride is offline
If you have a good fab shop around you then have it fixed.
Old 03-30-2013, 11:49 PM
Mdt1992's Avatar
Mdt1992
Mdt1992 is offline
thanks oldbird!
happened to run by this a few mins ago, sorta vauge on the description but im thinking this comes with the part you need if you wanna go the used route.... http://www.ebay.com/itm/VACUUM-PUMP-FOR-97-96-95-94-FORD-F350-7-3L-DIESEL-power-steering-bracket-/261190637951?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cd02cd97f&vxp=mtr
Old 03-31-2013, 12:57 AM
oldbird1965
That doesn't look bad at all and your welcome!
Old 04-01-2013, 10:40 AM
zthayer's Avatar
zthayer
zthayer is offline
Thank you everybody for all your help and as soon as I figure out how to give adaboys on here I will take care of that. Everybody has been very helpful in helping me figure out whats wrong with my truck since I bought it and I'm greatful! Have a blessed day!
Old 04-01-2013, 12:44 PM
oldbird1965
refer to post #9.
Quick Reply: 97 7.3 front engine bracket problem
