Q for anyone using Speedway Disc Kit
Old 06-16-2016, 07:56 PM
JPMallory's Avatar
JPMallory
JPMallory is offline
I didn't have that problem. Do you have a picture to show where things are hitting?
  #32
Old 06-17-2016, 02:13 AM
Mervy49's Avatar
Mervy49
Mervy49 is offline
Originally Posted by johnnydevil55
Did any of you guys have an issue with the drivers side caliper hitting the axle when turning left? I don't have the toyota steering box hooked up yet. So I'm not sure of the turning radius. But my caliper does hit the axle when I manually turn it to the left.
Yes, I discovered that also when I installed the brake setup. I'm using the original bottom shock bolt and instead of installing the original nut on it (back side off the axle) I found a couple of those old style wheel lug nuts with the longer barrel and used that to act as a stop. The threads matched so I figured this will work. The wheel go through the whole swing and doesn't hardly detract from the turning radius. In fact it seems to work perfectly as a stop. I'll probably get a few chuckles from the purists but I figure if there's a way to make something work, why not. Besides, I couldn't find the original.
Hey, I even have a pic.
  #33
Old 06-17-2016, 07:25 AM
johnnydevil55's Avatar
johnnydevil55
johnnydevil55 is offline
Here is a picture with what i'm dealing with. Like I said it might be okay once I get the steering box on and the wheels.
  #34
Old 06-17-2016, 02:39 PM
JPMallory's Avatar
JPMallory
I suspect you'll find that you won't ever turn wheel far enough to hit once you get the steering box hooked up.
  #35
Old 06-18-2016, 08:37 AM
johnnydevil55
That's what I'm hoping for. Now I need to find a pair of steel wheels that'll fit. I have the 5 x 4.5 kit up front.
  #36
Old 02-19-2022, 10:39 PM
tip49's Avatar
tip49
tip49 is offline
Wish I would have found this thread three dsys sgo
I had the same question for Speedway about the outer spacer being optional but nothing but crickets. You would think after 8 years they might at least update the instructions to eliminate some of the heartburn when installing the kit. Thats what makes this site so valuable.
Nice to know the explanation and now I am going to try using the original spindle nut and no spacer.
I had issues with the inner bearing not seating over the spindle adapter and had to remove material from the adapter so bearings would fit over it.
Schuyles
17
03-30-2014 10:21 PM
newguy399
11-12-2013 06:36 AM
Huntfamily53
13
12-02-2011 04:33 PM
mike1589
03-23-2010 04:33 PM
jcg82
04-02-2006 03:35 PM
Quick Reply: Q for anyone using Speedway Disc Kit
