Replacing Starter on 390
lol. i just replaced mine. 76 truck with headers. with the wheels turned left, i used a regular old wrench and sat on the ground behind the wheel i just reached in there and did it without even poppin the hood. but with the headers i had to take the header loose to get it all the way out thru the bottom. a 1/4" drive ratchet with deep socket and a good 8" extension(or 2 or 3 short extensions) will also get the upper-most bolt too. a long time ago i replaced my starter bolts with stainless steel hardware and have never had issues being difficult.
i personally have found that it really helps if you run the top bolt in from the backside of the bellhousing and use it like a stud it makes mounting the starter a breeze and then all you have to do is stick the lil 1/2 inch nut in your socket and about 8" extension like 7636074460 said but that is just my personal preference i find it easier to put nuts on things instead of blindly stabbing
ford390gashog
13
01-08-2004 05:38 PM
