1958 Remod
1958 Remod
Greetings! I have a 1958 Ford F-100 Short bed pickup that I am in the process of restoring/modding/repairing, and I am having a beast of a time trying to find anyone who has access to a steering gear box for this truck. I have found a few places that will rebuild mine, but it involves shipping the core cross country (I'm on the East Coast), having it rebuilt to the tune of upwards of 500 dollars for starters, then having it shipped back. Not a real big fan of this idea as it seems there are just way too many things that can go wrong during that trek. Does anyone have any ideas for something that might be a close fit or functional replacement for this box? I haven't driven it for three years, since my ex wife was scared it would kill me as it has over a half a steering wheel's play in it before it engages, but I'm itching to get this thing back on the road. Any help is greatly appreciated.
Welcome to FTE. You can rebuild your steering box yourself. Not really a lot to them if your not afraid to tear into something new. There have been multiple discussions here about the topic.
You might find this thread interesting https://www.ford-trucks.com/forums/1...1960-f600.html
The steering boxes from the larger trucks will fit in the F100's with a few modifications. I have a box out of a F500 in mine. A little bit bigger gives you more mechanical advantage which translates to easier steering. I would also be surprised if your worn steering box was the only factor in your steering slop. Those front ends get pretty loose after 50 - 60 years.
I agree 100% about the larger steering boxes being the way to go. I just got one in mine and I love it. They are a stronger box and will last even though they are only slightly larger.
When I went to check out that MH 4x4 F-600 I couldn't believe that they were using the same gearbox as the f-350's but they did and the original box in that truck was still tight and steered nice!
If you want to consider power steering, see this technical article.
Toyota Steering Box Swap For 1948-1960 Trucks .: Articles
on
Two things that I believe that they Do Not explain about this conversion.
1: You lose the used of the Horn Button on your Steering Wheel as there's no place for the wire to run out of any more, because the end of the Hollow Shaft is now welded over.
2: There's a Rubber Bumper Stop mounted on the Frame Rail for when the truck Bottoms Out, that they Remove because it's in the way & it's removal has caused some problems for me & others.
I've done Toyota swap on a 51 and everything was great. Gonna start the swap on my 60 in a few weeks.
There is a kit from Mid fifty to keep horn in steering wheel.
Horn Conversion, FStock Column, Toyota Steering - Ford F-100 Parts
64rednwhite
03-10-2017 08:58 PM
70STEPSIDE
11-02-1999 05:35 PM
