driveshaft ?
I get 25 3/4" on the C6 from bell housing to t-case mounting flange. I can measure the ZF later today if need be, but I had to move the crossmember back just less than an inch for the ZF, so I'm pretty sure it isn't 4" longer. And whatever difference there is was easily accounted for in the splines on the drive shaft.
Thinking of the splines, I know that when I put a 2wd truck on my lift I have problems getting the rear drive shaft off because the rear axle swings forward and the splines bottom out on the shaft. But, I don't have that problem with a 4wd truck, even after installing the ZF. So, there are still splines left.
Gotlift03
03-16-2007 11:03 AM
fordsrgrt
12-05-2006 09:17 PM
Jerry Gougeon
11-15-2004 05:20 PM
Franken-Truck
10-22-2003 09:14 PM
