4.9L / 300 running rough ... Need Some Help
got a 1987 F-150 with the 300 6cyl. 4X4 ... when i first start it up it will idle fine for a few seconds and then die ... the only way i can keep it running is to unplug the air line to the Mass Air Flow Sensor ... it stays running and is actually driveable but runs rough and i have to ease into the accelerator or it just bogs down ... also has no power, terrible exhaust fumes, and gets about 8mpg ... if i plug the air line back into the MAFS while it's running it dies and then won't start back up unless i unplug it ... i replaced the MAFS a while back and it didn't make a difference ... i pulled the IAC valve off and cleaned it ... not sure what to check next??? was thinking maybe the EGR valve or a vacuum leak somewhere ... any ideas would be much appreciated
If you get in the truck and turn the key to the "on" position (not start), does the fuel pump(s) whine for 1-2 seconds then stop ???
That tidbit of information would be helpful..........
Oh, and are you sure you have a "Mass Air Flow Sensor" instead of a MAP sensor ???
Bob
when i turn the key on the relay clicks immediately once and then clicks again after a second or two and then immediately after it clicks the second time there is another click that sounds like it is coming from the high pressure fuel pump, but i don't think the high pressure pump is actually kicking on ... no buzzing sound or vibration, just the click ... the in-tank or low pressure pump is actually on a toggle switch under the dash ... not sure why, it was like that when i bought the truck but the in-tank pump kicks on with the toggle switch and seems to run fine ... i checked the fuse and it is fine
sporkacus
06-14-2014 10:38 PM
10strokin
05-25-2010 12:55 PM
