Re-route Oil Filter Water Lines?
Old 03-14-2013, 05:40 AM
JWA's Avatar
JWA
JWA is offline
Received 1,394 Likes on 1,103 Posts
First time oil change on my new-to-me '03 E250 w/5.4, a bit surprised how the water lines are routed, different from my '00 and '97. This is probably very typical of year and engine:
Has anyone changed the hose fittings to make it easier getting to the filter? That's just one clumsy location and positioning IMHO!
Would appreciate anyone's experience or fix for this.
TIA
Old 03-17-2013, 06:50 AM
JWA's Avatar
JWA
JWA is offline
C'mon----someone's dealt with this too I'm sure?!?!
Old 03-17-2013, 10:22 AM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
IMO, it would be easier to buy a strap wrench. It usues a ratchet either a 3/8" or 1/2" drive, if it's up there a socket extension.
Old 03-18-2013, 06:14 AM
JWA's Avatar
JWA
JWA is offline
Yeah I'm sure there are a few work arounds I can employ---thanks for the suggestion '79Ford.
I have an idea using a funnel held by a hoop attached via magnet somewhere near the filter allowing me to completely drain it without handling it. I do my oil changes in the driveway so not making a mess with spilled oil is a concern.
Any other ideas are still appreciated----of course I might be worried about nothing.
Old 03-18-2013, 11:07 AM
1979 Ford's Avatar
1979 Ford
When I change my oil I pull the plug first, if the filter can't be reached by the drain pain I let it all drain from the oil pan, replace the plug reposition and change the filter.
The filter should hold with the filter wrench. If not a take your free hand and spin the filter off and hold it upright until you can put it in the drain pan.
That is what I do. On mine I can get in and change it without any issue.
Old 04-01-2013, 01:14 AM
WP1's Avatar
WP1
WP1 is offline
Recently swapped a 4.6 into an 04 f350 that came with a 5.4. Not a van, but had similar issues with the water/oil cooler lines in the way. Ended up removing the water cooler and plugging the lines about an inch after they come off the main hose. It has been towed with and the temp gauge never gets above half. Just an extra part to fail IMO.
Old 04-01-2013, 06:35 AM
JWA's Avatar
JWA
JWA is offline
Thanks WP1-----somewhat my thoughts too.
I've considered swapping out the '03 filter/block adapter for an '00 or earlier--have both those vans, the water hoses routed quite differently, more convenient for filter removal.
Since this is a driveway job every time I want to make a funnel holder allowing me to punch a hole in the bottom of the filter and it draining into a catch can overnight in most cases. I'd almost eliminate any spillage.
I appreciate all the suggestions here----some good ideas!
BLK94F150
General Automotive Discussion
11-27-2007 01:25 PM
deepbass
1978 - 1996 Big Bronco
06-05-2005 11:21 AM
cphill58
02-03-2005 03:20 PM
skeleton
08-20-2002 10:37 PM
Quick Reply: Re-route Oil Filter Water Lines?
