RPM max
No disrespect, but you have a truck. Drive it like a truck. If you want a hot rod get a hot rod. If you take care of a 302 it will outlive cockroaches. I had a uncle with a 302 in a 86 half ton have 342xxx with one valve job and well taken care of before my cousin wrapped it around a tree.
Now I have a 302 in my 3/4 ton and it is far from fast but it pulls more weight than it should and will do anything I ask it too. And to answer your question 5500 is the max I would rev it but I rarely see over 3k on mine
thanks yall!! fordmanva, i know that you was not trying to disrespect me, i was wondering what the max rpm was of my truck so that way i knew how far i could take it without blowing my engine. its not like i am trying to hot rod my truck but it doesnt like the interstate and i needed to know the max rpm so i could get my truck up to speed better!!
i know a truck should be driven like a truck, hence the name "truck." by the way, i have a camaro to hot rod around in, but i need to know the max rpm so i know how far it will go before it blows, i dont plan on pushing it that far. i needed to know my threshold. plus i need to buy a tachometer for my truck and needed to know my range.
I realize that this conversation is centered around a 302 engine, so this is just for humor...
I have a 1985 with 4.9L engine and normally drive like an old grandpa, BUT this morning on the way to work, I felt "froggy" and wound it to 3000 RPMs and the engine wispered to me, "why did you do that?"
What you are missing is your engine condition and mileage. There is a reason high end racers rebuild after each race. Parts wear, tolerances grow, problems push tword the surface. You may be able to wind out a 500 to 80,000 mile engine to 5500. But as miles grow id definately cut that number. I completely understand your question and why you want to know but just like being a 20yr old then aging to 50. There are things your not as good at, not as fast, not as strong, not as much endurance. Just keep that in mind.
Ranger80
68
01-11-2012 07:32 PM
fordtrck302
05-04-2005 10:06 AM
RyanMiller
11-11-2004 09:01 AM
Rodriguez
12-04-1999 09:53 AM
