Modular V10 (6.8l)
Which exhaust studs
Old 03-09-2013, 10:43 PM
oxbronco's Avatar
oxbronco
oxbronco is offline
Which exhaust studs
So I have several broken exhaust manifold studs on my 2002 v10, I have read that the so called improved ford studs still suck, what would you recommend for replacements? I am also thinking about replacing the y pipe, it just looks so restrictive. Are there any good aftermarket y pipes out there? I have also thought about fabing one myself out of stainless. Thanks for the input!
Old 03-10-2013, 04:10 PM
windyhill's Avatar
windyhill
windyhill is offline
I reused my manifolds, it didn't work, I then had them machined flat and tried again, still didn't work. I used the ford replacement studs and they are no improvement over the old ones. I also used the dorman ones they are way cheaper and are as good or better then the stock ones for what its worth. I'm in the process of getting the best headers I can, and scrapping the #$%* stock manifolds for good. Good luck
Old 03-10-2013, 06:02 PM
oxbronco's Avatar
oxbronco
oxbronco is offline
I would be going for headers as well, but i cant spend the money right now. My truck also needs ball joints, front wheel bearings, rod ends. I guess I will be going with the dorman studs for now. Im hoping i dont break off too many more studs in the head!
Old 03-10-2013, 08:30 PM
windyhill's Avatar
windyhill
best way I found to get them off was mig weld to the end of them tell you have enough to grab onto with large vicegrips. then work it back and forth a very little bit at a time tell they loosen up. The heat really helps. Also soak them with PB blaster then again before you start heating them. if you have enough stud (3/8" or so) then get a stud puller from snap-on, really works well. Patients and more patients!
Old 11-02-2013, 09:46 PM
ashleyroachclip's Avatar
ashleyroachclip
ashleyroachclip is offline
Apr probably makes a replacement stud, that is where I would check first.
Old 11-03-2013, 12:21 PM
Shepherd2's Avatar
Shepherd2
Shepherd2 is offline
I just used some grade 8 bolts.
Old 11-03-2013, 01:01 PM
sammie0126's Avatar
sammie0126
sammie0126 is offline
Do not replace with studs, put in a grade 8 or better bolt.
Old 11-29-2013, 09:50 AM
swadmx's Avatar
swadmx
swadmx is offline
I ended up just buying the Banks headers as I don't want this issue again with the oem parts or improved studs .
The bill was 930.00 to remove the studs and install Banks headers and Y pipe.
I also ordered the Banks exhaust but have not had it installed yet . I don't like the fact I have to use some of my stock pipe and I really want the stock sound , I have a Tundra with a Borla system that robbed all my bottom end and cab noise was ughhhhh.
So stock exhaust and Banks headers , first impression of the sound was , " I still have an exhaust manifold leak " lol
I don't drive the truck much and it took a week to get it back so I don't really have a seat of the pant review on just the headers . I can say there is a hill I drive quite often that the truck pulled in a higher gear ( with a small load of wood )that before headers truck would slow to 40mph and require a some pedal and a downshift .
90limited
Modular V10 (6.8l)
18
12-16-2018 07:34 PM
SuperDutyScaler
1999 to 2016 Super Duty
04-15-2018 03:26 PM
SuperDutyScaler
13
02-12-2018 09:24 PM
shark1979
Modular V10 (6.8l)
03-24-2010 09:25 AM
husk
1997 - 2003 F150
03-14-2009 01:31 PM
Quick Reply: Which exhaust studs
