Bronco II Ford Bronco II
Electric Issues
Old 03-07-2013, 06:29 PM
28to4088broncoii's Avatar
28to4088broncoii
28to4088broncoii is offline
Electric Issues
Hello ALL I need some help..
I have a 88 Bronco II that I have installed the complete dash, wiring and engine from a 94 explorer. Ran great for the last 2 years.
My problem is that two nights ago someone tried to steal it from my front yard, they tore up the steering column bad, but they were not able to get the lock cylinder out. I had to use a hammer and beat the key into the cylinder and after using pliers I was able to turn the key and work it on and off. When starting the truck before when I turned the key on I would hear the fuel pumps come on and go off after a few seconds. Now when I turn the key on I do not hear the pumps but the truck will start and run and when I turn the key to the off position I hear the pumps run for a few seconds and then turn off.
I pulled a new column from a 94 explorer today and installed it, and still have the problem.
Does anyone might have a clue to what could be causing this? Could the attempted theft be causing this or is it just a coincidence?
Thanks,
Louis
Old 03-08-2013, 08:55 PM
28to4088broncoii
I think that my problem is a bad relay, I am going to replace all of them.
Louis
Old 04-10-2013, 02:30 PM
mdgaf's Avatar
mdgaf
mdgaf is offline
Yeah sounds like main relay to me.
traildad
1997 - 2003 F150
11-30-2017 08:29 PM
rv7plt
07-02-2017 12:45 PM
2012ford350
1997 - 2003 F150
09-10-2012 05:06 AM
ottawaguy
1997 - 2003 F150
02-07-2010 08:04 AM
frozentexan
Escape & Escape Hybrid
10-07-2007 11:14 AM
Quick Reply: Electric Issues
