Power Steering fluid change
Old 03-05-2013, 08:44 AM
KennyG228's Avatar
KennyG228
KennyG228 is offline
Greetings!
I am one of the folks who got in on the Red Head group buy and I am now planning my work. I want to change the power steeing fluid and I saw some of the threads on how to do it. My question is should I flush the fluid before or after I change the box? If I do it before, it seems to be a waste of fluid. After, it seems that some of the old fluid will still be in the system. My Ex has 183,000 miles on it. Any suggfestions would be most appreciated.
Old 03-05-2013, 10:01 AM
rcboats1's Avatar
rcboats1
rcboats1 is offline
Do it before. What you call wasted fluid I call insurance.
Let us know how you like the change to the Red Head, I am thinking that I need to do it soon.
Old 03-05-2013, 10:10 AM
EXv10's Avatar
EXv10
EXv10 is offline
It's not going to matter.
Old 03-05-2013, 10:53 AM
timf150's Avatar
timf150
timf150 is offline
You can go either direction but I did it in this order.
1. Changed the fluid.
2. Go for test drive to make sure all is good
3. Install the RedHead
4. Top off fluid after the change.
5. Turn on vehicle and move steering left to right and check fluids.
6. Take test drive and check fluids - it may be noisy for a bit but should go away if fluids are good
You will not loose that much fluid when you change out the steering pump but it will require more.
Tim M
Old 03-05-2013, 11:08 AM
EXv10's Avatar
EXv10
EXv10 is offline
You're only talking 75+- cents loss in fluid. I thought I was frugal.
Old 03-05-2013, 11:23 AM
Archion's Avatar
Archion
Archion is offline
If I were installing a ~$400.00 steering box, I would put serious thought to changing that 45.00 pump and relatively cheap fluid anyway, and flushing the PS cooler. just my 2c.
Old 03-05-2013, 03:32 PM
KennyG228's Avatar
KennyG228
Thanks for the feedback. No, I am not frugal, I am cheap but I do want the best for my baby. I priced a box at my local Auto Zone and it is $60.00 with resevoir, $45.00 without. Since my box is due tommorow (yes I called early yesterday), I will order a new box tonight and do it all tomorrow. I am excited to get it done!
Old 03-09-2013, 08:18 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
Flush system before the swap. Change all the parts out and top off the system.
You could pull the return line and run the engine and drain the system before swapping the parts out.
Whatever MAKE SURE you do flush the cooler!
Old 03-10-2013, 07:43 AM
Patriotic Rottweiler's Avatar
Patriotic Rottweiler is offline
More cheap insurance... Install the Magnefine 3/8" filter R038M-P. I got 4 of them from eBay for about $12 each. I plan on changing them every year.
Old 03-10-2013, 02:17 PM
KennyG228's Avatar
KennyG228
Thanks for the feedback folks. I swapped out the pump and the box, then I filled and flushed the system with some mercon v. after everything was clean, I added an in line filter from autozone. Everything is now squeaky clean.
diggerrigger
09-28-2017 08:36 AM
Krazy_Knuck
2004 - 2008 F150
03-29-2011 08:36 PM
qdude79
1997 - 2003 F150
05-01-2006 06:41 PM
steakman_usaf
04-05-2000 12:57 PM
Quick Reply: Power Steering fluid change
