Replacing Oil Cooler.. What else should I do or upgrade?
Old 03-04-2013, 09:33 PM
ExFire's Avatar
ExFire
ExFire is offline
Oil cooler is leaking so I’m going to be replacing it and a coolant flush. What else do you suggest that I replace / upgrade or mod with the oil & coolant drained? I’m new to fords and the 7.3
Parts on order for the job
• Oil Cooler & Seals
• Oil change with filter
• Coolant flush
• New Coolant cap
• Thermostat & Housing
• Lower hose
• Upper hose for dual alt setup
Old 03-04-2013, 11:43 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Completely back flush the engine and refill with an OAT Extended Life Coolant.
Gooch's Coolant Flush Procedure and In-Depth Coolant Information - FTE
Stewart
FL SuperDuty
08-02-2018 09:03 AM
FL SuperDuty
12-22-2017 10:29 AM
mark r / 019
11-25-2013 08:52 AM
Thermo2008
08-14-2011 08:03 AM
yooper00
09-23-2007 08:40 PM
Quick Reply: Replacing Oil Cooler.. What else should I do or upgrade?
