Massachusetts Chapter Join Chapter, Leader: donjamer
Somewhere I can get 4.88 gears done
Old 02-27-2013, 05:41 PM
06F150CFCT's Avatar
06F150CFCT
06F150CFCT is offline
Hey Fellas,
I was curious if anyone knows any place in Mass/RI/CT...screw it, New England....where I can get front and rear 4.88 gears installed on my 2006 F150 FX4. I have talked with a place in Shrewsbury, MA called Mitchell Drivetrain that quoted me $2632.38 for everything but that seems wicked high. I know people in LA can get it done for 2100 and people in Oklahoma and Texas can get it for 1700-2000. I understand everything is more expensive up here and that shops are a dime a dozen but there has to be other shops. I am just looking for other places that would be trustworthy as I am not going to just drop it off at any ol' shop and have them do it.
Thanks for any advice/options.
Old 02-28-2013, 02:31 PM
BIGKEN's Avatar
BIGKEN
BIGKEN is offline
Received 7,110 Likes on 4,192 Posts
Try Scott Beck at Beck's Automotive in Greenfield...413.522.1864. Scott used to work at our dealership...Master Certified Diesel Technician. Tell him that Ken from Ford of Greenfield referred you.
Old 02-28-2013, 02:50 PM
06F150CFCT's Avatar
06F150CFCT
Thanks BIGKEN...appreciate the help. I'll get in touch with him if this place in CT (CT Axle) doesnt get back to me or work out.
Old 03-12-2013, 10:36 AM
batchman's Avatar
batchman
batchman is offline
And only a little closer than Greenfield is:
Elias 4WD Center
178 Wallace Hill Rd Townsend, MA 01469
978-597-8432
I've found them to be spendy too, but what you seek is a spendy job.
- Jeff
Old 05-08-2013, 08:12 AM
BumpJr's Avatar
BumpJr
BumpJr is offline
Im sure this job is already done but just to add. Mitchell's is a great shop and stand by their work. I'm not sure about gearing but they made all my custom axle shafts. Elias is also another great local 4x4 shop. Have no experience with Becks.
Old 05-10-2013, 03:08 AM
kastein's Avatar
kastein
kastein is offline
Wow, how's it going Bump? Had no idea you were on here.
There is also Wzorek's in Westfield MA. I have heard good things about them from a few people and reportedly as of a few years ago, they would do a diff for $175 if you supplied parts/install kits etc and brought them the axles out of the the truck.
Mitchell's is out near me, they do quality work (I had them cut down and rebalance a driveshaft for me a few years ago) but that does seem expensive.
Old 05-10-2013, 09:15 AM
BumpJr's Avatar
BumpJr
BumpJr is offline
Not bad Ken. Ford fan first. Jeeps second.
I've heard mixed reviews about Wzorek's but no personal experience.
By the way Happy Birthday Ken.
Old 05-11-2013, 05:17 PM
kastein's Avatar
kastein
kastein is offline
Thanks!
06F150CFCT - I believe an 06 would have a high pinion 8.8" front and a low pinion 9.75" rear? What brand gears did Mitchell say they would be using? I see USA Standard (reportedly louder gears) 4.88s for around 160 a diff on RockAuto and Nitros on JustDifferentials for around 260 a diff. Add to that a master install kit for each diff (150/front and 250/rear) and possibly around 100/diff worth of other materials (RTV, lube, bearings to make setup bearings, etc) and the materials should cost around 1100 bucks I believe. Beyond that it is labor - gear setup is not easy, but it's not incredibly difficult either if you are patient. If you have access to a lift and the tools there is a good chance you can do it yourself with some patience/attention to detail, but expect to spend at least several hours, probably a day on each one, that's how long it took me to do my first (and so far only) diff regear.
It doesn't appear that FMS makes 4.88s for the 8.8 (that I can find anyways) but Motive and Strange also appear to.
RedBirdin96
04-15-2017 10:32 PM
DSN46
10-30-2013 11:11 AM
Sparky83
Virginia Chapter
03-09-2009 02:15 AM
bryang
1978 - 1996 Big Bronco
13
09-22-2005 09:06 AM
mwpierson
1999 to 2016 Super Duty
02-23-2005 01:24 AM
Quick Reply: Somewhere I can get 4.88 gears done
