fuel consumption for a 239 flat head V8?
Hello from a new member with an old 1952 F3. I appreciate the site very much and welcome the valued information. The post you mentioned well I don't belive they'll be around for the long run. Ok simple question-----
Gas tank is out of truck being cleaned and coated inside so using a 21/2 gal can inside the cab as a temp. Rebuilt the carb and starts real well now as long as the battery has a full charge. The generator is on the list as next here shortly. The question is how is the fuel consumption expected to be for a 239 flat head V8? I can watch the level in the can go down just with the truck at an idel. I had the carb apart twice as the first round the float adjustment was obviousley wrong and now corrected but something still not right I believe.
Thanks,
Dennis
Thanks,
Dennis
Received 1,354 Likes
on
1952 Tow Mater
Thanks,
Dennis
on
Could we see some pictures? Here is how.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
JPMallory
09-01-2015 04:29 PM
Sned66
04-08-2012 10:12 PM
F(rozen)250
Electrical Systems/Wiring
34
10-30-2011 09:54 AM
