8 lug wheels on 1960 f100
Old 02-24-2013, 04:04 PM
manlikesford's Avatar
manlikesford
manlikesford is offline
I am confused. I have a 1960 f100 with 8 lug wheels. I believe it is a f250 suspension. I thought the frame was also but the Vin #F10J0R52768 matches the title and according to Vin decoder f100 6 cylinder. Did someone put 3/4 ton suspension on a 1/2 ton frame? Also the rear driver has 9 leafs and rear passenger has 8. The front have 7. Trying to figure out what I have. I have the cab, bed, engine, tranny and front clip off. Thanks for any info offered.
Old 02-24-2013, 04:12 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Sounds like just what you said. ... 3/4 ton axles on a 1/2 ton. Sometimes the two have different frame widths so other factors may be involved. 2wd? Straight front axle? What wheels are on it? I have at least two trucks with different amounts of leafs on opposite sides, but have to admit, I'm the culprit. They have to sit level, so I do what it takes (without spending $)
Old 03-02-2013, 06:32 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by manlikesford
I am confused, I have a 1960 F100 with 8 lug wheels. I believe it is a F250 suspension. I thought the frame was also but the VIN: F10J0R52768 matches the title.
F10 = F100 / J = 223 1V I-6 / 0 = 1960 / R = San Jose CA Assembly Plant / 52768 = 1960 Numerical Sequence of Assembly, the trucks specific serial number.
No F100 of any year came with 8 lug wheels on a 6.50" bolt circle. Should have 5 lug wheels on a 5.50" bolt circle.
Front springs are the same 1957/60 F100/250 2WD, could have either 6 or 7 leaf spring packs.
Rear springs interchange 1957/67 F100/250 2WD. 1957/64: F100's could have 7 or 9 leaf spring packs, F250's could have 7 or 10 leaf spring packs.
1965/67 F100's could have 5, 6 or 9 leaf spring packs. 1965 F250's could have 7, 10 or 11 leaf spring packs. 1966/67 F250's could have 6 or 8 leaf spring packs.
btw: I was confused...once. 1989: While on vacation in WA, driving on I-5, I see a billboard that says "Do the Puyallup" Wondered what the hell does this mean? Found out later it's the local county fair.
weldjet
05-14-2018 06:33 AM
chetspencer
03-27-2018 11:39 AM
merten
08-28-2017 04:03 PM
bigjohn87
10-13-2012 12:33 AM
Raucous Dog
05-18-2012 11:32 AM
Quick Reply: 8 lug wheels on 1960 f100
