dashes in odometer
Ummmm, what are you driving? I had the same symptoms
My '01 SCrew would have the dashes, crank good and not start, yours?
What I would do is cycle the key from On to Off three or four times quickly and eventually the Odometer would display the numbers and start. After about a month of irregular starting, it "cured" itself.
I thought it had something to do with the PATS key not being recognized. It's been over a year and hasn't returned.
Others here may lead you to the actual problem.
GonzoCSU
06-16-2017 10:25 AM
