Oil pressure for a 1994 f-150
need help what does the oil pressure needs to be at on a mechanical gauge for a 1994 f-150 v8 302 2wd, was reading 7 psi but gave it an oil change and filter and a new oil sending unit and hasn't drop from10 psi is that normal when its idling when its all warmed up thank you
im using 10w30 before all this the gauge was reading low on the red line and it bounced around when it was idling and when i would drove it, it would go up to the middle , so i replaced the unit and gave it and oil change because the previous owner did not changed it with in a year. now with the new unit and oil change its reading normal runs with no problems no noise everything works fine its just with the mechanical gauge that read 10 psi at idling. the engine has 121000 miles
It is a 302 run it until it dies. If you ever have tore down a few of these 302s it is amazing they run at all. I have seen stuff from the factory that was unreal in these years. As long as it reads in the NORMAL RANGE Ford says it is OK. I wouldn't worry about it. If it isn't knocking your fine. I had a 88 T-Bird with almost 200,000 miles 302 & it had a piston slap that when you started it you thought the pistons were swapping holes. It is still running & I sold it in the late 90s. I see it around every so often.
What I do on these older motors is run 10-40 & a half a quart of Lucas Oil treatment. But when you put it in leave your oil a half quart low, start it get it to operating temp warm the Lucas to room temp & pour it in then drive it for a half hour. WHY? that way it gets mixed with the oil & once mixed it won't separate. If you just dump it in it a cold stopped motor it just goes to the bottom of the pan & over time it mixes most of it but not all.
Craig
Craig
oldmanbergie
12-09-2010 12:06 PM
Countrywfo
03-03-2010 08:34 AM
yama916
11-27-2005 02:00 PM
