oil pressure sending unit, low oil pressure
well my 92 clubwagon 5.0 has been running good for the past year. Ive recently been seeing the needle for the oil pressure guage sitting slightly lower, at N or normal... which is pretty close to zero...
ive done a search and read thru lots of threads, seems like the guage is a dummy and does not accurately portray the actual pressure. so max pressure on these fords are about 7psi?
where are the oil pressure sending unit located on these V8? I think im just gonna go ahead and change it as its only 5 bux from the store.
ive read posts where after changing the sending unit the needle was back up around half... motor has only 106k on it.. and i use 5/30 synthetic for now... theres some oil leak but not significant and i keep the oil topped off all the time.
Mine recently did almost the exact same thing. The gauge was reading fine then suddenly dropped to about half its normal reading to about the N in normal. Then after running for about 10 minutes it drops to the peg at zero.
When it first did it I paniced and shut it off instantly. Checked the oil level (full) and the lead to the send (still attached). After checking everything out and finding nothing I started it back up and the gauge was back to the N again. A few minutes later, zero. I got it home and put a hand-held mechanical gauge in place of the sender and pressure was normal. I don't remember the numbers but it seems like it was something like 6 psi at idle and maxed out somewhere around 30.
I bought a sender for $7 at autozone but it is the wrong connector. Checked senders at a couple of other stores and they were all the same. ??? I guess I will have to get one at the Ford dealer.
Steve
'95 Clubwagon XLT
Steve
'95 Clubwagon XLT
Originally Posted by pfogle
Steve, I'd be a little concerned with 6psi at idle..... That's really low, low enough to starve the bottom end and kill your bearings.
Steve
'95 Clubwagon XLT
Well, I just changed the sender in my van. I got one at carquest, they did list different senders for a gauge and a light. I looked at both and they are different. The light sender costs about half what the light sender does.
I installed the new sender and the gauge was back to normal, with the reading between the m and a in normal.
Steve
'95 Clubwagon XLT
Steve
'95 Clubwagon XLT
Steve
'95 Clubwagon XLT
Steve
'95 Clubwagon XLT
I then verified this with the Ford schematics, and it is indeed the case.
That switch makes contact between 4.5 and 7.5 psi, according to this schematic. If someone wants a copy, I could find this again and post it as a picture.
I remember the advise then given, which is to install a real 'sender' (hence a varaible resistor, depending on the oilpressure) from a van, or an F type from somewhere in the '80s. This one would give you the real presure indication.
Of course, I do not know the partnumber or make, sorry........
Cor
Rocketattack
04-25-2016 09:00 PM
Goinnuts
12-02-2015 03:12 AM
FordXLT1990
11-27-2015 08:14 AM
hoorahlibbo
10-23-2012 09:01 AM
Hank79
12-27-2003 01:08 AM
