Spray-on coating for a Flat-Bed
We have a 93 f350 XL Flat-bed dump truck that is used mainly for hauling junk from construction sites. It just had a new bed put on last year, and the scraping of the bed from dumping has started to wear off the black paint, and the scratches are starting to rust.
What would be the best spray-on coating for this that won't have to much grip so the junk still slides out easily?
I don't think it matters what you paint it with, no paint is going to stand up to having 2X4's with nails sticking out and weighted down drug over it day after day.
You could cover it with 3/16" aluminum plate. If you attach the sheets with stainless steel countersunk flat head machine screws either tapped right into the bed or drilled though with a nut under the bed it would be nice and flat so things would slide easily and it would take a long long time to wear through.
It wouldn't be cheap though, a quick online look shows a 4x8 3/16 plate at $288 and you would most likely need 2. You could probably find it cheaper - that was the first place I looked. 3/32" was $188 for a 4x8, but I'm not sure if that would hold up for you in the long run. 1/4" would be even better, but it costs quite a bit more.
Would also be a bit of work to drill and countersink it, but you would only have to do it once.
Edit: Sometimes large scrap yards keep the plate they get and sell it reasonably, or if you can find somebody who makes large tanks nearby they might be able to get you a deal on some.
That's what I was thinking, the bed liner would grip too much. I've never used the POR15, but I will look for some.
Thanks
Either would probably a waste of money given your intended use.
Plate aluminum holds up pretty good on Rollbacks, I've seen some abused for years, some fairly good gouges to be sure, but never anything through and some of them see a lot of heavy sharp steel everyday.
They don't make very good rollbacks because the welds like to pop loose, but great junk haulers.
I live smack in the middle of several large scrap yards and exporters so I see a lot of rollbacks.
That's not universally true. Something like Line-X leaves a hard, glossy finish - I imagine their goal was to try to mimic as much as possible the slippery finish of a drop-in bed-liner. Something like Rhino-liner is indeed intended to provide a softer, "more grippy" surface.
I have had Rhino, Line-x and Scorpion. All 3 of them had SUPERIOR "holding" over a plastic slide in or just a plain bed
