OBS Alcoa center caps
I tried posting a WTB in the classifieds with no luck, so I thought maybe someone in this section might have one lying around and would part with it...? I find it hard to believe that here at my local JY there isn't any lying around but I have been checking there for months with no luck!!
Thanks Brad, but I am wanting the one's with the Ford logo on the rear center caps, like they came from the factory.
Here are some push thru style
Alcoa Wheels
Alcoa Wheels
Just giving you options since the original design was **** pore and they go flying
here are some for logs for the push thru ones
FORD 3d car decals for wheel center caps
Yes they do, I have done it on Several trucks
I find them all the time. The problem is the clips are broken, hence why is along the side of the road
Will report back one way or the other.
Mike
SETOF4 Ford Truck Van 8LUG 16" Chrome Wheel Center Hub Caps Nut Covers Alloy Rim | eBay
Of lesser quality than the OEM ones are are know to fly off pulling out of your driveway. And they snap into the recesses in the wheel, not the lug nuts like the newer style
Ancient thread, I know, but I stumbled across it while looking for something else.
Just to report back, I've had the ebay caps on my truck now for months with no issue. Yes, they're meant to grab around the outside of the lugnuts. So, to ensure it'd be a tight fit, I turned each lugnut so that a corner of the hex was as far from the center of the wheel (radially) as possible. Yes, that means my torque specs aren't exact, but it shouldn't be off by a huge factor. I've had no issues with the caps coming loose (or coming off), so I'm pretty happy.
That being said, if I ever have to take the truck anywhere for work that requires removing a wheel, I'll probably take the caps off myself so they don't fall off on the way home.
Mike
Mike
on
I have a few sets of the original ford hub caps. The chrome is a little bit bad on a few of them, but the trick is get lug nuts that do not interfere with the center cap install, so that means like a 13/16 I believe socket size lug nut, then bend the wires slightly to grab the wheel. I have never lost one, but I don't beat my 96 truck, so that could be part of it too. Agreed on a poor design, but the look is unmatched for me. I feel like a 97>95 with factory alcoas and all the hub caps is the finest look these trucks ever had.
