4R100 Automatic Transmission flush-pics and video
#31
Received 5,240 Likes
on
#32
Jeff
#34
#35
I have a question before I start the tranny flush about fluid temps.. I have always drained my engine oil with a warm engine so I guess I would do the same for tranny? Obviously right off the road might be too hot to drop the pan but shouldn't it be at least warm to help the fluids flow? What do you all suggest? Thanks for all the help!
#36
#37
on
#38
Not a bad idea, I did have a pretty good spill when I dropped the pan because of what was left in the pan and filter, and there was constant dripping until I put the pan back on.
#39
#40
Thanks for posting this Jeff. I can't wait to get started on this project next weekend! The post about letting the pan drain overnight is a great idea! I had planned on using SuperTech (Walmart) Mercon/Dextron atf. (sold by the gallon) Anybody have any comments or cautions on this?
#41
on
#42
The information in the owner's manual is outdated. It says to use MERCON, but Ford doesn't license the production of MERCON fluid any longer. There is NO genuine MERCON fluid being produced anywhere. There are a lot of fluids that say they are for use in applications that used MERCON, but are they MERCON fluids? Nobody is checking.
Ford changed the specs for MERCON V in 2006 to make it compatible with the 4R100.
MERCON V is the right fluid for a 4R100 now, not MERCON.
The following users liked this post:
#43
on
#44
I was waiting for the hose to turn bright red or pink in the video. Seems it got cleaner but it wasn't like a light switch when I did my flush. When I did mine (20 quarts) the last run, the fluid was dark brown and then like I said, like a light switch the fluid turned bright red/pink coming threw the hose.
My original fluid I believe never changed in 160K miles:
Right after the trans flush I did my power steering/brake booster flush with the same fluid and hose.
#45
No light switch. It cleared up around the 1 minute mark though. It would have been easier to see without the asphalt background. I was waiting for the air, but then I did the math in my head and realized I'd already wasted 3 quarts of new fluid.
I also used the same setup for the PS flush as well.
