96 7.3 4x4 E4OD with an odd transmission issue. Help me figure it out?
I feel the transmission may be giving up the ghost.
A couple months ago it gave me a transmission slipping code while towing a car. I reset, and have not been using OD. Haven't had an issue with that code since.
However, now there's a new issue. I plow with this truck, and need to reverse for extended periods of time/distance. When I do so, the truck does not want to go back into a forward gear. It started out that I had to drop it in to "1" in order to get it to catch a forward gear. Once it catches, it's fine. Shifts normally through the gears. Well, once time it didn't want to catch. I had to rev the 7.3 to ~2500 to get it going in a forward gear (while I was in "1")
I stopped reversing for long distances, and didn't have the problem again. Tested it out one more time by reversing for ~100', and had to drop it in to "1" in order to catch a forward gear again.
Is it a valve body isses/servo pack? I'm not getting any errors/codes.. Man, I miss my manual!
77 steve
31
02-10-2024 11:02 AM
1994FordF-350MegaCab
26
02-17-2019 04:23 PM
abajc3
12-09-2014 07:01 PM
big79bronco
02-11-2013 06:16 PM
RIKIL
03-11-2012 12:15 PM
