stuck in 4x4
stuck in 4x4
how do you get the shifter out of 4x4 in these trucks? every time i use 4x4 i can never shift back in to 2x4. so i just end up unlocking the hubs and leaving the shifter in 4x4 and drive around that way. eventully after i drive around some i can finally shift back in to 2x4. but why cant i shift in to 2x4 right after im done with 4x4? thanx
My 205 was a pain to shift with the stock linkage too. Sometimes I would lean back and kick the stick. Recently I twin sticked it and wow what a difference. It slides in and out of gear just like the main box. I can even kick the rear into low on the street, get rolling, and clutchless shift it into direct on the fly. It's kinda like deep reduction in my Kenworth.
Normal, even when using 4wd properly it's normal, if you're using 4wd on dry pavement you're exacerbating the driveline bind and something will eventually break, usually an axle U-joint.
4wd should only be engaged in loose traction situations i.e. snow/ice/dirt/sand/mud etc., never on dry pavement.
i got a chance to try it out today. that backing up trick really works. no more stuck shifter.
i have another question about these old 4x4 trucks. are they shift on the fly like newer trucks? when im driving down the hiway doing 65 sometimes ill hit snow dry road and more snow. can i shift from 2x4 to 4x4 back to 2x4 or will i cause my t case to explode?
^ ditto
You can shift between 4H and 2H at speed as long you work the throttle correctly, you don't want to be accelerating or decelerating as you shift, you want the throttle in a "neutral" position, so to speak.
This should be obvious but never engage 4L at speed, the truck needs to be stopped, or at a very slow crawl.
SasquatchF-250
04-25-2014 10:47 AM
mirage5058
01-02-2011 05:43 PM
