89 f-250 with "mustang" 5.0 swap ?'s
hey guys i just picked up a 89 f-250 5.0L 4x4 project that somewhere down the road has had a "mustang" 5.0L swapped into it, the PO said he tried and tried and could never get it to run right (he did not do the swap himself, he bought it that way) when i got it from him, it was in shambles. i just finished plugging in the wiring harness for the EFI as well as the 40+ damn misc vacuum lines
i bought a new battery (everything gets power and seems to work as it should) i gave it a spits of starting fluid and she fired up and ran on like 4 cyl. honestly.. it sounds like some wires are backwards and/or the distributor is out. but what else would cause this? is it common for this swap to run poorly for any reason?
and what 2 firing orders could it possibly have? or is there only one for the truck and the mustang 302?
after i hear from you guys what the firing order is, i'm gonna re-stab the dizzy and double check the wires for my own security before moving any further.
thanks guys!
-Nate
thanks guys!
-Nate
okay i redid everything and it still runs the same, it will idle and run but it is definitely not firing in cylinders #5 & #6. (every port on the manifolds is hot except for these two.
i did confirm that they are both getting spark, and have GOOD reason to believe they are getting fuel too (smells very rich/white smoke) i took the DS valve cover off to check the rocker arms/valve springs and it is all nice and tight.
why the hell else would this be happening???
thanks
-Nate
thanks
-Nate
on
What computer is in it? Did the PO try to convert the truck to mass air and only get half way through the wiring or do something really stupid like plug a mustang computer into the truck harness? That won't work because these older truck are wired for batch fired injectors while the Stangs were sequential injection.
nezwick
53
12-27-2019 11:02 PM
351Cleveland C4
03-15-2017 10:26 PM
