Shock mount question
There are other things that complicate an answer. Are you asking about the upper shock mount, or the one on the spring plate? Are you also going to a 9" for better gears? How much of a notch are you putting in the frame?
Most 9" have shock mounts on the axle tubes, that can be cut and re-welded where you need them. Naturally you'll need to measure the at-rest length of the shocks you need, add and subtract 3" at least to get the overall range.
The notching could effect the stock upper shock mount.
Just don't angle them any more than the already are. Reversing the axle on the springs will drop the rear significantly (the diameter of the axle) but will require quite a bit of additional work, it's not just an unbolt rebolt project. Mid Fifty sells short shocks for this type mod, I'd expect that their sister company Classic Haulers would have some similar.
kb48
1947 and Older Ford Trucks
15
07-18-2011 04:25 AM
Huntfamily53
04-15-2009 09:14 AM
