300-6 motor mount frame perches
Hi there all, I'm thinking of acquiring the necessary stuff to swap my 351W with a 300-6 I have in my possession. My truck is an "83" w/4spd, and I understand most everything I now use will work except the radiator and engine perches. I don't mind buying new radiator but I DO need the perches.
My question is what years will work for the perches? I would assume 80-86 perhaps but some have suggested later years as well so the question is which year perches will fit my "83?
On edit I have thought i should ask..will my current clutch bell-crank/ball assembly work as well?
I hope to source these soon for a swap when the weather warms up some..
Thanks for the input you may have.
good input
The frames are all the same up to 96, so all those will work.
Does any of your bellcrank/clutch linkage screw into the side of the engine block? If so(I know most chevies did) you are going to need a different bracket obviously, since the 6 is a tall skinny engine compared to the v8.
Maybe a little more searching will come up with that answer for sure.. Again thanks for the input
86fordtruck
10-18-2011 08:20 AM
steve5140
13
03-31-2009 05:37 PM
Alan89
06-04-2002 07:01 PM
