LED bulb replacement help
Old 01-27-2013, 08:07 PM
montey2005's Avatar
montey2005
montey2005 is offline
I'm looking to change all the bulbs on the inside of my 2012, F250 Lariat, to LED's. Can someone direct me to a "preferred" website or offer any suggestions on products? I'm also looking at some rear replacement lights so any experience would be welcome. 2008 2012 Ford F250 F350 Super Duty LED Tail Lights Rear Brake Lamp Pair New Set | eBay
Going to change the side marker lights and third tail light too.
Thanks for the input.
Old 01-27-2013, 09:36 PM
madsonp's Avatar
madsonp
madsonp is offline
The tail lights you're looking at are about the same thing I put on mine, and I'm really happy with them. As far as your other bulbs, you might take a look here. I've bought some stuff from them and have been really happy with their products. LED Lights, Bulbs & Accessories - SUPER BRIGHT LEDS
Old 01-27-2013, 09:39 PM
montey2005's Avatar
montey2005
thanks. I'll start the hunt
Old 01-27-2013, 10:32 PM
maltesecross's Avatar
maltesecross
maltesecross is offline
I changed all of my interior bulbs as well. I ordered them from this site. You will need 3 of the festoon bulbs, i used the 578 1 LED bulb was plenty bright enough for the rear courtesy/map lights.
The front requires the 194 LED bulb, 2 of them, I used the 6 LED SMD wide angle wedge in the front. I did have to trim the reflective surface a 1/4" to make it fit.
I also change the cargo/3rd brake light 194 bulbs. There is 2 in there that are clear bulbs and one red. Used the 15 LED SMD base tower. Very pleased with this one, lights up the whole bed.
The license plate take s the 194 also. I went with the 5 LED wide angle wedge. Wished i woulda went brighter on these. The "SMD," whatever that means, seems to be a brighter bulb overall.
Old 01-27-2013, 10:47 PM
montey2005's Avatar
montey2005
what do you mean by 15 LED SMD base tower? did you change the housing?
PITS's Avatar
PITS
PITS is offline
SMD = Surface Mounted Device which basically means the diode (LED in this case) is mounted directly to the circuit board without wires that would normally poke through the boards and be soldered on the other side. This can make for much smaller devices with the same or even brighter output in the case of a light.
Use this guide to determine the bulb numbers and then go to Amazon (first) or eBay to find the replacement LEDs.
https://www.sylvania.com/en-us/appli...s/lrgmain.aspx
Local automotive shops generally try to make a great deal of profit on these little items.
Old 01-27-2013, 10:49 PM
Dim Sum's Avatar
Dim Sum
Dim Sum is offline
Oh man, thanks to all who've helped here! I was looking at LEDs yesterday and now I have a better idea of what I need!
Old 01-27-2013, 10:54 PM
maltesecross
I meant it was the name of the bulb. 15 is the number of LED's in the fixture...
194 LED Bulb - 15 SMD LED Wedge Base Tower
Part Number: WLED-xHP15-TAC
Old 01-27-2013, 11:30 PM
montey2005's Avatar
montey2005
Thanks. Did you have a hard time prying open the interior lights?
Old 01-28-2013, 01:30 AM
PITS's Avatar
PITS
PITS is offline
Yes.
There is an extremely fine line between popping the lens off and totally destroying a very expensive proprietary flimsy piece of plastic.
Old 01-28-2013, 08:47 AM
montey2005's Avatar
montey2005
any tricks you wanna share?
Old 01-28-2013, 09:41 AM
my_crib_too's Avatar
my_crib_too
my_crib_too is offline
Received 1,183 Likes on 364 Posts
On the technical page, it would be great if we had a listing of all existing bulb numbers and the LED replacement. It would be a fun little project to upgrade all the bulbs on the truck.
Old 01-28-2013, 03:58 PM
Joshua Sirchuk's Avatar
Joshua Sirchuk
Joshua Sirchuk is offline
I've been to SuperBrightLeds.com and they seem way over priced to me. Does anyone know of a site that has less expensive bulbs?
Old 01-28-2013, 04:24 PM
maltesecross
Old 03-27-2013, 07:02 PM
frdf250's Avatar
frdf250
frdf250 is offline
I have an entire list of LED replacemnt bulbs if anyone wants it from when i did my 2012 f250.
Quick Reply: LED bulb replacement help
