Axle Shims - lessons learned
For anyone in a situation where they need to shim their rear leaf springs to correct a pinion angle, I learned what was almost a very expensive lesson about Axle shims. I'm sure the majority of you already know this but for those "incoming dummies" I thought this would be helpful.
In the photo below are two types of shims.
The one on the right is actually called a wedge and has a large center hole with a grove down one side. I now call this the lazy shop version, because they can be slide between the axle and spring pack with very little effort and w/o removing the centering pin or anchoring them to the pack. DO not ever install or let anyone else install these on your truck. They will eventually slide out! If you look at the goemetry it is just a matter of when not if they will slide as they are only held by the force of the spring plate and the Ubolts.
The one on the left is a steel shim with a centering hole. This anchors to the entire spring pack with a centering bolt. These are not going anywhere.
Conclusion:
Left side of photo - solid steel - centering anchor = good.
Right side of photo - aluminum - no center anchor slide in groove = bad.
Conclusion:
No lift just the springs with one caveat, I got them off a 2002 F250 that I bought both the axle housings off of a Dana 60 and LS 10.5, was a package deal. I found out once I got everything home that the PO had put aftermarket springs on his F250 so if you are interested they are actually ProComp srpings they are 22410 front and 22415 rear and I have no blocks, the springs are sitting directly bolted to the axles. I am about 3 1/2" lifted from stock with these springs. At first I was not thrilled because I thought I was getting V and B codes but I like the ProComp springs, the stance works for me and they ride well. I do need to update my sig and correct that, get asked that question often.
Does it ride stiff or close to stock?
Sam are you sure about those ProComp part numbers? The front 22410 shows that it will fit but not the rear 22415. This is according to the Amazon auto section which is right about 50% of the time. I am going to do the V/B swap in the spring but I have a ton of points that are usble via Amazon from the X-mas shopping that I could get the ProComps at a really good price.
Front 22210 - listed as 4" of lift
Rear 22415 - listed as 6" of lift
BUT I removed the factory block in the rear, I think if you go with the 22415 in the rear and you leave the block you would end up much higher in the back.
The 22410 fronts get you 6" of lift in front according to Summit's website. A little confusing because you are saying the issue was with the 22415 number and that is correct. Anyway hope this helps.
Dano78
04-06-2022 09:23 AM
