Broke my rear end
chances are that the spiders broke inside it can probably be fixed unless your gears got destroyed by the chunks of steel..... if it is indeed a 9" you can just grab another entire unit and replace the whole unit and not have to worry about it to much that way if you need info on how to change or repair never hesitate to ask its what we like to do around here is answer questions and help others with what we know so these older trucks can keep on living......
Whatever the front ratio is, the rear should be the same.
The rear axle ID tag was originally located at approx 5 o'clock under one of the bolts that retains the carrier (pumpkin) to the housing.
Sometimes you may find the tag under any of the bolts as people may not put it back in the same place.
But the bad news is, many people forgot to reinstall these tags while reassembling the axles, so many are missing today.
calorchard
01-01-2010 08:51 PM
joestratton1
05-18-2008 07:22 AM
moiamiervous
12-12-2004 02:20 PM
holla-if-ya-hear-me
01-25-2004 10:22 PM
blu93gt
09-10-2002 11:39 AM
