390 problems again
Old 01-19-2013, 07:55 PM
jw4hd's Avatar
jw4hd
jw4hd is offline
390 problems again
Hey guys, I have a 73' f-250 with a 390. It has been running fine for awhile and now all of a sudden it wants to barely idle and dies often and sometimes when in gear it will die.
Thanks!
Old 01-19-2013, 08:16 PM
kwe45919's Avatar
kwe45919
kwe45919 is offline
Doesn't give us alot to go on. As of right now, it could be a vaccum issue, a fuel issue or a spark issue. Have you checked anything out or can you give us a better idea of what's going on? If you're not a mechanic type or not sure about your way around the motor/engine bay, let us know that as well so we can walk you through some ideas. Give us a a bit more information and we can get ya started.
Old 01-19-2013, 08:33 PM
jw4hd's Avatar
jw4hd
jw4hd is offline
Yeah I am not the mechanic type unfortunately. Now that you mention vacuum lines I think I should take a good look at that because just a week or two ago it was not running well and it was because of the lines was not hooked up. I will have to check that. As far as more description, the truck had been running just fine, then today it didn't want to idle in park, it kept dying. The day before it ran completely out of gas, not sure if that would have anything to do with it. I will try to investigate more to get more details. Thanks!
Old 01-19-2013, 08:46 PM
kwe45919's Avatar
kwe45919
kwe45919 is offline
Running out of gas could be anything from a clogged fuel line to a weak fuel pump...or just running out of gas in the tank of course.
If it's dieing at idle, I'd definatly look around at the vaccum lines. Make sure they are in good shape and on nice and properly secured. Just for poops n giggles, check and wiggle the carb (hopefully you can't) to see if the bolts may have come loose over time or that the gasket hasn't given up the ghost. Sooo many things to check, some more obvious than others when it come to a vacccum leak. Good luck and post up what you find.
Old 01-19-2013, 11:43 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Which carburetor does it have?
Josh
biggyfan1
08-24-2013 02:54 AM
Lil Ryan
05-16-2012 12:18 PM
Dpayne1965
09-24-2011 09:13 PM
Prodigyranger
1983 - 2012 Ranger & B-Series
07-26-2004 04:15 PM
seans64'
1978 - 1996 Big Bronco
02-26-2004 09:04 PM
Quick Reply: 390 problems again
