1997 f-350 460 Gas
Why would you bother? Unless it is bad, it is not hurting anything.
If your engine is not built, it will not significantaly limit the performance of the engine. Especially if the rest of the exhaust is stock, as othe parts are a much greater restriction.
If your set on it, then no, you do not have to tune te engine to run without it. Unless you have a MAF equiped truck which does have a downstream O2 to check the operation of the cat.
on
NICKknackNICK
05-18-2011 02:45 PM
supercab79
08-26-2010 09:29 PM
wicked5ltr
10-22-2003 05:17 PM
Fireman
1999 to 2016 Super Duty
12-26-2002 12:40 PM
