1997 f-350 460 Gas
Old 01-15-2013, 07:30 PM
swentz's Avatar
swentz
swentz is offline
1997 f-350 460 Gas
Wondering about removing the cat on this thing...any ideas? Do I have to reset the module??
Old 01-20-2013, 02:02 PM
BrianDguy's Avatar
BrianDguy
BrianDguy is offline
Why would you bother? Unless it is bad, it is not hurting anything.
If your engine is not built, it will not significantaly limit the performance of the engine. Especially if the rest of the exhaust is stock, as othe parts are a much greater restriction.
If your set on it, then no, you do not have to tune te engine to run without it. Unless you have a MAF equiped truck which does have a downstream O2 to check the operation of the cat.
Old 02-04-2013, 03:15 PM
cbakker's Avatar
cbakker
cbakker is offline
Brian is correct.
I removed mine only because I put the whole banks powerpack kit in mine. It saved me lots of headaches by not reinstalling it.
Without any other mods, and unless yours is plugged, you will not benefit from removing it.
VONxRUBENxLA
07-22-2011 12:49 AM
NICKknackNICK
05-18-2011 02:45 PM
supercab79
08-26-2010 09:29 PM
wicked5ltr
10-22-2003 05:17 PM
Fireman
1999 to 2016 Super Duty
12-26-2002 12:40 PM
Quick Reply: 1997 f-350 460 Gas
