E4OD Operation
E4OD Operation
I have an E4OD behind my EFI 434 'M' block in my '53 F100, and I have an E4OD behind the carb'ed 302 in my '83 F100. I use a Baumann Controller to control the shifts, but I only have one Baumann. I swap it between vehicle as I need it.
I am building a DIY controller that I'll use in one vehicle and keep the Baumann permanently in the other.
The questions that I have are:
When is the EPC Solenoid energized?
Is SS1 for 1st gear?
is SS2 for 2nd gear?
Does energizing CCS lockup the torque converter?
When does TCC get energized?
How does the trans get into 3rd & 4th gear?
I am monitoring the Transmission Range Select, and the Transmission Speed Sensor, as well as the TPS, and I have a table for the shift points. I only need to find out which solenoids are energized for each gear.
Whenever the controller is powered. There is A LOT more you need to ask about this solenoid.
No.
No.
No, it engages the coast clutch. That's why it is called the Coast Clutch Solenoid.
When the torque converter is locked. That's why it is called the Torque Converter Clutch solenoid.
By using SS1 and SS2.
No, you need a lot more than that.
How are you going to control EPC? That is Electronic Pressure Control. A large part of the stock PCM is devoted to getting the right pressure at the right time inside the transmission. The PCM controls the EPC solenoid to get the proper pressures. Too little pressure and the trans slips and it toasted. Too much pressure and all the shifts slam, and sometimes hard parts break.
This chart should help:
[IMG][/IMG]
No.
No.
[IMG][/IMG]
The Baumann uses Alpha-N control, and that's similar to the old T/V cable.
The controller Sinks current from the EPC. I need a circuit to control the path to ground.
is there a curve for Fluid Temperature?
Not anymore. I had that when I was at Ford, but it didn't belong to me so I left it there.
You can make one yourself fairly easy. Measure the resistance of the sensor after it's been in your freezer for a while, at room temperature, and after heating in the oven to about 220°F. Three points will give you a good enough transfer function.
