2010 brake fluid loss? Help
My 2010 screw 5.4 has only 20K on it and last week the low brake fluid light came on. Yes I know I need to do the pads and with the little miles the truck gets I was waiting on slightly milder weather to address this. I added fluid and went on my way. Last night the light comes on again, my guess there is a leak somewhere. BTW truck stops fine.
First question; Any recalls on the brake system?
I bought the extended warranty so since this probably isn't pad or rotor issue should the dealer fix the problem?
I'm in a real bind here as my lady in is rough shape health wise and I need this truck ready to roll at all times.
Thanks Much
Wayne
Thanks Much
Wayne
Dealers flat out scare me. I drove down to them today, of course the service manager doesn't understand how vehicles work! Got an appointment for next Monday. Thought about things and bought a good set of front pads since it was 45* today. When I got to the right side I found the leak. It was the bleeder screw that must have been leaking since the truck was built. Small enough that when I saw a drop in the reservoir level I chalked it up to pad wear. Now If I had brought the truck in they Might have found the problem or just sold me new pads. I never have had any good experiances with dealers. Basically the only reason I bought the Extended warranty was for dash electronics.
Well in that case I would strongly suggest you get your money back, I'm sure they will prorate what you have left of it, stick it in savings and wait for a failure. Dealers scare me too, my last trip to the dealer involved actually meeting the moron that worked on my truck........very very disheartening. Good luck!
jwhopson
1997-2006 Expedition & Navigator
04-01-2010 09:29 AM
