brake question.
Old Apr 30, 2003 | 12:13 AM
joebeta's Avatar
joebeta
brake question.
well im here again with more trouble.today i noticed that i had some fluid leaking.i didnt check to see from where yet becuase i was running around.while driving i hit the brakes and the brake peddle started rumbling and made a deep grinding noise.this happened 2 different times today.i have stated this before.i bought her about a week and a half ago.so im not sure what the previous owner really did(93 xlt).im also hearing a wierd rattling form the front wheels when driving.its like a real faint squeek.i just want to make sure its something that isnt major.also the abs light is on all the time.is it easy to change the brake pads on my own?thanks in advance.
Old May 2, 2003 | 06:52 PM
marragtop's Avatar
marragtop
brake question.
Sounds like you've worn the brake pads completely down. Easy to replace the pads, not so easy to do the rotors. The pads probably won't explain the leak you are referring to unless a caliper or line is leaking.
Old May 2, 2003 | 08:53 PM
joebeta's Avatar
joebeta
brake question.
well the leak i discovered was the steering fluid.the cap was not put on correctly and the fluid leaked upwards.i havent had any leaks since then.i found some pads for 29.99 at struass.i know i could find them for cheaper somewhere else.is there any brand in particular?
Biggziff
Oct 21, 2020 09:53 AM
Timmons125
Modular V10 (6.8l)
Aug 22, 2012 11:20 AM
nitro3421
32
Apr 9, 2012 09:45 PM
Kyle_KleinSS
22
Apr 3, 2011 04:48 PM
decaruby
Mar 28, 2011 01:05 AM
