Banks DP install ?'s
Thanks! the muffler is more less there for inspection purposes, it really dosnt do anything, it and the mandrel bent tail pipe were $100 shipped from summit, just got alot of other things to deal with on the truck first then maybee down the road ill go 4". Thanks again
Banks Power Gale Banks Engineering 52103 - SummitRacing.com
on
part number is unknown.not listed in the banks instructions.it's just called the intermediate pipe.if you want to go that route,just call up banks and they'll hook ya up.
kinda sucks they don't just make the dp with the bend for straight exhaust.but then they couldn't sell ya an intermediate pipe right lol?
the intermediate pipe from banks is of course with the made for banks turbo dp.but im sure it works for that made for ats 093/factory '93-'94 turbo dp too.
also,now would be a very (the only lol) good time to wrap that sucker with 2 layers of header wrap.but when you make the pipe thicker with wrap,the more the floorboard must be "persuaded."
but if your after snappy throttle response,or at least greatly reduced lag,you'll want to wrap it,along with your cross overs too since your down there.
The ATS aftermarket turbo downpipe exits straight. At least mine does. Just to add that for comparison. Banks must have there version bent a little differently for some reason. It might clear the transmission a little easier that way?
on
wrapping the DP keeps the heat in and this supposedly (see how careful im being here lmao) helps speed up velocity in the pipe.if this is true,then the turbo will spool quicker.
here is a funny ars read with a couple going at it and in the end,the one guy catches the other agreeing on the point where it matters anyway (then he gets mad lol)
is it ok to wrap downpipe ?? - Dodge Cummins Diesel Forum
how much? who cares imho lol,your buying the wrap for the cross overs anyway,and the down pipe is out where you can wrap it with ease.would be silly not to wrap it.it takes no time,and like you say even if it does nothing else,it keeps under hood temps down,making it well worth it regardless (especially for those running them open 6637 hot air intakes.)
lets go pats!!
lets go pats!!
