Heated/Cooled seats not working
I've posted this before, a couple of years ago but I wanted to post again to see if there is any more insight in to what might be happening on my 2004 Expedition Eddie Bauer.
One day both front seats quit heating and cooling. They both quit at the same time and will neither heat nor cool. I figured it was the fuse but that doesn't seem to be the issue. I replaced it and things still don't work. The buttons no longer light up either.
Does anyone have an idea of what might be going on?
Thanks.
Wyn
Thanks.
Wyn
Thanks.
Wyn
Thanks.
Wyn
If both lights work depending on what year your expo is 07 and up the large plug connecting to your module could be the culprit if your light comes on but shuts off pretty quickly there is a negative wire that shorts out and it looses ground they have an upgraded connector to replace it sometimes it damages the module otherwise the thermostat is the other culprit if it burns up it will not heat witch is embedded into the fabric or the the heating element is fried or severed best thing to do is unplug the heating pad and do an ohm test like mentioned already hope this heads you in the right direction
motoman67
1997-2006 Expedition & Navigator
22
06-02-2018 12:50 PM
k9education
03-22-2016 01:00 AM
