Does anyone have an 'at home' procedure for Ranger transmisson flush?
Old 01-03-2013, 03:37 PM
ricer333's Avatar
ricer333
ricer333 is offline
This is something I've been scouring the interwebs for a few days now. I'm getting ready and over at the TCCA forums that I belong, I modified the procedure a bit. I just wanted to know if you all had an 'at home/diy' procedure that maybe a little better?
0) add in 1/2 pint of SeaFoam Trans Tune to transmission fluid 30 mins before doing oil flush and follow instructions (drive around or go through gears) to work in Trans Tune properly.
1) Disconnect trans-line from transmission. Follow back the line from the Bottom of the Trans-Cooler on driver's side of radiator to find the 'return' line
2) Turn truck on and pump out old fluid through the return line. This will take a minute or two. Turn truck off when fluid starts 'crawling' out of line to prevent damage.
3) Pour in 4 quarts of new fluid and pump out the new fluid through the same disconnected hose. This will get any remaining fluid out of the Torque Converter.
4) Drop the Trans Oil Pan. Clean up magnet and pan itself with some brake cleaner
5) Replace new filter and gasket for Transmission pan. Make sure magnet is back in pan and bolt pan to transmission.
6) Add in 9.5 quarts and shift through all the gears.
By my calculations, I'll need roughly 9.5 quarts of oil for the full fill in step 8, along with the 'new' oil drain that step 3 calls out. So, roughly 14 quarts of oil. Does step 3 have enough oil going into the system to 'clean' out the old stuff?
StrokinHer01
19
03-31-2018 01:32 PM
carbongs
12-19-2010 10:10 PM
orygunf150
2004 - 2008 F150
12-31-2009 07:16 PM
gvrangr98
1983 - 2012 Ranger & B-Series
02-13-2008 05:37 PM
phroman
03-04-2007 11:49 AM
Quick Reply: Does anyone have an 'at home' procedure for Ranger transmisson flush?
