1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
'03 F250 cig. lighter
Old 01-02-2013, 10:29 AM
919rider's Avatar
919rider
919rider is offline
'03 F250, FX4, CC, V10 if it matters.
My lovely wife bought me a pair of seat heaters for Christmas for my truck. They've got a standard 12v plug to put into the cigarette lighter. They work like a champ when plugged into the accessory power point, but don't work when I plugged into the cig lighter.
Since I'm not a COMPLETE moron, I checked the fuse (#12) and it was blown. Cool, easy fix. Replaced the fuse, plugged in and no power. WTF? Plug in the cig lighter and no response from that either. OK, check fuse again. Nope, fuse is fine.
So, what are my next steps? I'm a mechanical guy, not an electrical guy, so I always ask stupid questions when it comes to electrons! How do I fix a cig lighter? What do I need to check?
Thanks!
Kevin
Old 01-02-2013, 10:48 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
CJB fuse F12 goes only to the Data Link Connector (pin 16) and the cigar lighter. You'll probably want to break out the test meter or test lamp and see if you have power at either point. Also, look at the contacts for F12 and make certain that they are not damaged or stretched out.
This assumes that any fuse inside the heater plugs is also good. If the heater works in the aux point, then they're fine. If might just be a mechanical (shape) problem of the plug(s) on the heater(s).
Old 01-02-2013, 11:32 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
most of the time the cig lighter burns out, if you changed the fuse id get a 12volt test light and check the cig lighter to see if it powered. if not unclip the lighter and check the wire going to it if the wire is powered then just go to a Ford dealer and buy a new cig lighter and put it back together
Old 01-03-2013, 02:06 AM
hookedondiesel's Avatar
hookedondiesel
hookedondiesel is offline
Yep, ground your test light clip, and use the pointed part to test the "center"
point, inside where the lighter goes,
make sure you don't touch the sides of the light case, or you'll blow the fuse again.
Jason Whatcott
06-24-2019 11:04 PM
CharlieA1
Modular V10 (6.8l)
08-25-2013 12:53 PM
quietman
03-21-2013 09:06 PM
wcook1967
08-04-2011 10:58 AM
Danny Stroup
Electrical Systems/Wiring
02-03-2010 06:16 PM
Quick Reply: '03 F250 cig. lighter
