What would you do? camshaft journal broke 5.4 3v
Old 01-02-2013, 07:42 PM
Jeffrey Sutton's Avatar
Jeffrey Sutton
Jeffrey Sutton is offline
So the front journal on the driver side head broke allowing the cam to walk all the way into the cps.I have a 2004 f150 with the 5.4 3valve motor with about 140,000
So that leaves me with a couple of options
1. get a used or rebuilt head and replace the just driver side
2. Replace both heads
3. I've located a used chassis with a 5.4 motor with 120,000 about five hrs away. Just swap the motors
4. save up and buy a new long block
I cant wrap my head around whats the best viable option I work seasonally so right now im laid off and cash flow is slim to none
Old 01-04-2013, 11:11 PM
stangdude's Avatar
stangdude
stangdude is offline
I'm having my heads replaced right now for a similar thing. Damn camshafts don't have bearings in these modular heads, so they are deemed "non-serviceable". From what I've seen, it's only 1-200 more dollars to do a longblock as opposed to the heads and all of the other parts. Being an 04, I'd replace the cam phasers and timing tensioner too since they are known issues and have updated designs. They would be included in a long block. With these known internal issues in the early 5.4's I'd be hesitant to buy a used engine with 120k on it. You might be in the same boat in another year if you go that way.
Old 01-04-2013, 11:40 PM
aparise72's Avatar
aparise72
aparise72 is offline
I'd go with a long block if it was me and start fresh. I had the task of putting a reman long block in an 04 5.4 about a month ago that rolled a follower off the valve and wiped out the camshaft. Cost the customer about $6500 installed. And I thought that wasn't too bad for being a Ford dealership.
Old 05-10-2014, 05:51 AM
Jeffrey Sutton
Ended up going the used block route put 10,000 on it and
(no issues so far knocks on wood)
flyingtexan
1999 to 2016 Super Duty
05-13-2018 06:28 PM
flyingtexan
Modular V8 (4.6L, 5.4L)
07-09-2017 10:05 PM
54Sgt
16
08-22-2006 10:16 PM
warrens
04-09-2004 12:08 AM
jrod60
10-24-2003 07:57 PM
Quick Reply: What would you do? camshaft journal broke 5.4 3v
