Weird wiper problem
Weird wiper problem
I was warming my truck up this morning and I turned my wipers on to get the bit of snow on my windshield off. The wipers moved a few inches, stopped, and a mechanical buzzing noise is coming from under the wipers. I can move the wipers with my hand and they'll go all the way up and return to the bottom, but do the exact same thing when they move again.
I searched the forum but can't find anything about the wiper problem I'm having.
I also see a lot of discussion about GEM in relation to wipers, but I have no idea what that is.
you will get a better response
thanks
You need to get down to the wiper linkage assy. Ck the motor attachment and bushings . That is , if your motor is working . If it is working a splined shaft attachment has stripped or a bushing has broke loose . If motor runs and wipers do not work you have a mechanical problem . If you get acces to the linkage assy the problem should be obvious .
