Mustang question for a guru (sorry no mustang option in "Other Fords")
I purchased a set of halo headlights for a Ford Mustang, V6, 2003. The manufacturer instructions have you tap from the side marker lights so the halos are lit when the lights are on.
I would like to run the halos when the car is on. Is there an accessory wire I can tap without having to run wire through the firewall?
I can think of one spot, but you would need a relay to go with it. In other words, the spot you picked would have 12v anytime the keyswitch is on, but you do not want to use the same 12v to run the halo lights. You just want to use it to fire a relay. Then you could come off the battery with a fuse, go through the relay contacts, and then to the lights. I am thinking of the EECV computer power relay. You could even use the power that goes to the fuel pumps. Like I said you would not be using the fuel pump power to power the lights, just to trigger your new added relay.
khadma:
First of all, thank you for reading my request and taking time to help. I respectfully request that you re-read my post. The side markers are on only when you turn on the headlights. I want them to run constantly while the car is on. watch oncoming traffic during the day, you will notice the BMW's halo is always on even when the lights are not. I'm looking for the same result.
khadma:
I figured it out just after I submitted that post.
There really is none that I can think of, that doesn't have an important job already. In other words, if you had a problem with your new lights, it could take down the circuit that they are hooked to, and I can't think of an unimportant circuit under the hood that you could live without.
For instance if you had a small fender bender, and crunched one of the lights and the wiring or the lights shorted out. You don't want it messing up something important. Of course you could put a very small inline fuse to your new lights, and hopefully it would blow before the other circuit would, but it would be a close call probably.
I wonder how much current they really use?
Considering they are L.E.D's I wouldn't think they use that much power. I've resolved to simply hook it up the way Raxiom suggests and if it bothers me that much, I'll just go back in and change it later... Your way with the relays
donotmixwithh2o
10-11-2008 09:05 AM
